H2 Footprint
Can someone with an H2x printer do me a favor and measure the distance between the front and rear foot pads? I need to see if I’m going to have to have a bigger table. What I have now is 19.5" deep (495 mm), but I’d like it to sit back a bit from the edge. I do have room for it to hang off the back a bit if the feet are not out to the edge.
Much appreciated!
I am currently running a print, but after it finishes I will be adjusting the Z belt tension. I can measure the distance then.
Here you go, about 45.5cm center to center or 48cm edge to edge.
Thanks a million Maxim3D. I really appreciate it.
