Hey All,
What the heck is this sound coming from my H2C? It’s on but not printing, nothing sent to the printer. No fans are indicated on?!
Hopefully this link works to see the vid. The vid makes the sound very loud, it’s quite noticeable but not as loud as this make it out to be.
Thanks in advance for your help, really perplexed on this one…
Sounds like a fan blade hitting something.
I’d start with a power cycle, then turn fans on individually via the control panel to see which one it is.
It may be one of the fans that aren’t controllable, but this will help narrow it down.
Will try again but I did a power cycle, same noise, no fan indicated being used on power panel. I feel it’s not really a fan noise either but not sure…ugh…
If you face the rear panel does the sound originate here? The power supply fan always runs and isn’t reflected on screen.
Thank you for your post and picture, most appreciated! I am away for work until this weekend but will check as soon as I am back and post. Does seem to be emanating from that area when I was sticking my head inside the machine but did not look at the back side…
Does that fan run 24\7 if not printing anything?
Hi. Based on the video, it sounds like a compressor. If the noise is coming from the bottom-left part of the printer (when you’re standing in front of it), try listening from the back of the printer instead—that should make it clearer. How many months old is your H2C printer?
I have had it since around March of this year. To me it sounds like the right of the printer but that could be deceiving listening from the front. I will check from the back when I am home this weekend.
It does sound more like a compressor than a fan. What is the compressor used for?
WELP, came back from work travel where I left the H2C powered off for a few days and not it’s not making the sound!
Never got back to ya. Sounds like time may have cured…but yes, believe power supply fan never shuts off.
Thank you, that would make sense as well…I’ll keep an eye on it!
