H2C printing with Silk /Metallic filament
I am 99 percent sure this is what @NicPlays3D is referring too
For the silks, mostly Bambu, ESun, or Amolen; I have a few other randoms in the mix. For metallics, Bambu and Sunlu. I do have one ZIRO twinkling gradient that I had to manually calibrate for good prints, but for the most part, Bambu’s profiles have been pretty solid with silks. For the Sunlu metallics, they print perfectly with the Bambu profile; it’s almost like it’s the same stuff with slightly different color offerings.
Edit: I’m just realizing something else you mentioned after I posted this. Why are you thinking temps and brands are another variable with the FTS? Once the filament gets loaded in the extruder it is extremely unlikely that the FTS is causing problems. If you are getting the filament loaded without issues but have poor print quality it is more than likely an issue unrelated to the FTS.
Yes, I agree. But the problem seems two fold:
  1. Sometimes the filament drive will report failure and require pulling back and reinsertion after cutting a length off. This occurs more with Silk than std PLA. That why I’m interested bypassing the AMS. I really like the effect of some the 3-color Silk / Metallic filaments.
  2. Other times, the model will fail with spaghetti issue’s part way through the print. Particularly when printing the tall slender legs of animals. That could be my failure to adjust the suggested parameters correctly. That’s why I’m interested if filaments using RFID will overcome the need to make manual adjustments.
    I use a lot of Sunlu PLA, but haven’t tried there multicolor.
Thanks. I saw that a while back and will try it to avoid swapping the PTFE tubes to the 2nd head of my H2C.
I hear you man. So many people in the forums going off about things that they have little understanding of. So many unrealistic expectations and uninformed opinions.
