H2C won’t cut filament after upgrade from H2S
I am finishing up the upgrade for my H2S to H2C and I’m having problem filament, cutting left and right sides also, I think I’m having Y access over travel.
I installed the Y axis limit blocks but they don’t seem to be working very well.
a couple more photos. It looks like my Y axis goes back to far for the Filament stopper cutter to reach the toolhead filament cutter.
The black lever the presses on the cutter in your first pic has skipped a tooth. Just push it back to where its supposed to be. This happed to me when a PTFE tube for TPU got caught on mine. It will click as it goes into the correct position. Make sure you know the correct position. Its either flat against the rail (tool head parked) or a perfect 90* if the toolhead is lined up to hit it.
I had the same problem.
Easy fix if you follow “cutter stopper tooth jumping repair guide” in bambu wiki
