H2D Cutting Issues
Got the cutting module kit for my H2D - managed one print successfully.
Im now getting the following error:
The Cutting Blade offset calibration failed. This may affect the cutting accuracy. Please refer to the Assistant to check if the blade tip is worn.
When I try to calibrate - it wont let me do it as I don’t have a camera or laser module?
I also purchased just the cutting module kit. Unable to calibrate, error right when it starts calibration (lowering bed). Unknown error 0300-404c081801
I would try to take the blade out of the blade holder and put it back in. I say this because I got the same error, changed blades and it went away. I then went back to the original blade later on and that seems fine as well.
Interesting… I will try that and report back!
Unfortunately, same error after changing to a new blade (unable to calibrate, error right when it starts calibration (lowering bed). Unknown error 0300-404c081801)
