H2D Exhaust
Is all of the exhaust of the H2D filtered, regardless of the heating / cooling mode? Is it healthy / safe to work in the same small (say 100 sq ft), unventilated room as the H2D while it is printing?
Printing what material?
I am no doctor, and I can’t speak to the included filtration of these things, but I don’t worry about PLA, PETG, PPS, PPA, nylon… whatever. Probably should, but I don’t.
I will not however under any circumstances print anything containing styrene without exterior ventilation. Styrene poisoning sucks. ABS/ASA, HIPS, etc.
It is filtered but I am not aware for any of the Bambu printers to have some kind of safety certification.
And how safe is to dump poisonous or toxic fumes just outside is another story.
Safer than inside. Every 3D printer on earth is absolutely nothing compared to what they’re doing to manufacture things globally.
Ye ye dump the gas outside and it become safer :smiley:. Isn’t that how the whole China industry works? :rofl:
You shouldn’t be here if you have a problem with 3D printing. What’s your alternative? Inhale deeply so it doesn’t affect anyone other than you?
As I am not living in China nor India but East Europe, I am looking for good solution. And I do not think it is bad for someone to be informed right? So this is why I am here, I am informing my self and also informing the others. Hope this helps.
But excuses like - hey lets do not care as 2/3 of the world are already doing it - I think are not good. Of course everyone should take his decisions and responsibility.
Dude this is a forum filled with hobbyists. The best solution we have to protect ourselves and others in our homes is to vent outside. Plain and simple.
Charcoal filters have a dubious level of effectiveness. If you really want to double down and protect the squirrels in your yard, use both solutions.
But why you forget about the cats?
Here is a picture with cat so should be safe right?
https://www.fnatr.com/products/fnatr-3d-printer-ventilation-system
I see what you say but you my also see my side, no? As DIY guys we ( usualy) do not have tons of money but sometimes we could do some not conventional approaches. To say it nicely :smiley: .
Here at work I printed a pair of the rear vent flaps from Functional Print Friday ( FPF - 3D Printed Bambu H2 Series Rear Vent Fins ) and then printed a user’s vent system ( H2D Ultrathin External Upward Exhaust Duct - Free 3D Print Model - MakerWorld ) and then plumbed it into the machine shop exhaust system. We print a ton of ABS and just having the gate valve open about 1" takes all the fumes out without causing the printer to work overtime keeping the chamber hot.
For my H2D at home I only print PLA/PETG/TPU and I don’t have issues with fumes with it in the office.
I’d more worry about all the additives they add to the filements. E.g. PLA itself is most likely not that bad. But PLA filement had undisclosed additives in it. Even BBL’s PLA “pure” is not as pure PLA as one could manufacture it, It still has 4 additives added to it intentionally.
Better be safe than sorry.
My H2D Pro sits in a somewhat ventilated basement.
It sits inside of a MDF housing with a rolling front that has air extraction in the top. Think of a setup like a vented hood that’s used in a chemistry lab to remove vapors from experiments. Whenever the printer uses more than 25 Watts, the vent turns on and extracts the air around the printer (till the printer stays below 25 watts for long enough)..
I have air quality sensors outside of the setup, and they trigger on me opening up the hood around the printer and the printer itself after it finishes printing. They only measure VOCs and fine dust, but that’s still a pretty good indication to me that my setup makes a difference in getting the nasty stuff out of the house and not let it accumulate inside the basement (and spread into the rest of the house eventually).
It might be overkill. Sure. I accept that.
It might also just as well not be enough to keep me and my family safe. But at least i did my best in that case.
I look at it like what happened when I was a kid: everybody thought asbestos was great: it isolated really well, doesn’t catch fire, and it was deemed safe at the time. It was used everywhere.
Nowadays we know better than to use asbestos, and out here there’s a deadline for e.g. home owners to remove all asbestos (encased properly or not) from all homes by 2034. It’s also a legal requirement that every sale of a home has to be accompanied by an official report of what asbestos is known to be inside the building etc.
Point is that knowledge of dangers of being exposed to something can come much later than the exposure to it. And by then it can be too late.
Sure we can say pure PLA is most likely safe. But even BambuLab’s PLA Pure is far from true pure PLA: there’s still a total of 5 ingredients in it. They don’t disclose at all what in their PLA basic. And for other filaments/makers: none of the manufacturers disclose anything about what’s actually in the filament, let alone what comes out of it while printing it.
I did build the vented hood for my printer and opted not to force extraction from the printer itself due to the heated chamber: if I extract the hot air, I’m defeating the purpose of the heated chamber. And if I don’t extract enough: there’s plenty of other holes around the printer for it to leak out stuff. Hence: I’m intentionally not touching the printer itself and instead make sure there’s a steady stream of air heading outside all around the printer, trying to make sure I catch everything it leaks and/or emits (or doesn’t) - I hope I’m erring on the safe side.
Not just China… Unless there’s actually enforced laws with real consequences, some billionaire will without a doubt prefer to become even richer at the cost of everybody else and without any care for the environment or other consequences of their actions.
On my H2D, an inline fan connected to the rear port still pulled air during printing with the exhaust flap closed. The top vent and rear flap moved together with the exhaust setting; the Filter switch didn’t let me keep the rear open with the top closed. I wrote up how I vent mine out a window, check my github page (danielyaa5) I haven’t measured airflow or air quality, so this is a setup reference, not evidence that your room would be safe.
