H2D-External Spool Temp setting not saving
I am trying to print some Bambu 95A TPU from a External Spool. I need the temp to me 230 first layer and 215 the rest. These settings work best for my object.
I open Bambu Studio and select my H2D in Device.
Set ext. Spool to Bambu TPU 95A,
Change to Prepare tab
I now click sync info and overwrite, I now see all my correct spools/colors including my Ext.(Bambu TPU 95A).
Set my object to use Ext. (Bambu TPU 95A).
Next to the spool color I open edit for the spool. Make my flow and temp changes under Print Temperature.
I now slice plate and go to print. right Nozzle gives warning. "Unable to Automatically Match Filament. I select Ext spool and hit print.
No matter what I do I cannot get the print to Honor/change to the correct temperature. Anyone have a Idea what I am doing wrong?
I figured it out. I had to select the High Flow Nozzle in the profile because it showed both.
What is annoying is that it shows standard nozzle and high flow nozzle even those only the high flow nozzle is installed.
