The latest available offline update is OTA 01.02.00.00 from August 2025. I see that the latest version has been posted for the H2C and am wondering when we may see it for the H2D.
The.03 firmware is currently beta testing a new version for the H series on the H2D. If you join the beta program you may still be able to join in. I would assume those fixes are rolled into that, but it is currently online only.
You will have to wait if you don’t want or can’t connect to the cloud.
01.03.00.00 was a bit more than a small bug fix based on the release notes.
yeah I came back to fix that. I’m sorry, got my numbers in a bunch. Sorry for the wrong info.
Either way it’s’ only available through ota, there’s no manual update file available.
That’s my point, they pushed the latest offline update for the H2C so am hoping to see it for the H2D as well. Maybe @SupportAssistant can help…
H2D firmware will also come soon. I will let everyone know with a message to this thread once it is published.
Thank you, I use a VPN a lot for work and for some reason it doesn’t play nice with Bambu Studio as Flow Dynamics Calibrations fail to send to the printer when I’m connected to my office via VPN. My only options are to disconnect from the company VPN or run in LAN mode and I’m finding using LAN mode to be much snappier all around so am starting to prefer it.
If you wish to do it quicker, you can simply create a hotspot on your mobile phone, connect the printer to it so you can perform the update, then go back to your regular setup. ![]()
I disconnected from the VPN to update but seeing that offline was posted for the H2C I figured I’d ask as wouldn’t mind having access to offline updates for the H2D as well. I know we use Fortinet for our corporate firewall and they block some pretty stupid stuff but when I request an exception IT says they don’t see where there should be an issue ![]()
Either way, I’m set but do find it odd that I have no issue queuing jobs to the printer while on VPN but can’t run Flow Dynamics Calibrations.. As an FYI, I forget the exact verbiage, but it goes to 30% at sending to printer then just blips out like it’s been sent but is never received by the printer.
The team has published the latest offline version: V01.03.00.00
