Hi,
i recently got the H2D and I need to make my first long print with PLA, and after that, another one with PETG HF, but I have a question I haven’t found an answer to.
With the X1C, I do this:
With PLA, I remove the top glass, leave the glass door wide open, and after the third layer, I lower the aux fan to 40% if the objects are small or medium, and to 30% if they’re large. This applies both in the summer when the room is 30 degrees Celsius and in the winter when it’s 20 degrees Celsius.
While with the PETG HF:
In the summer, when it’s 30 degrees Celsius, I remove the top glass, leave the glass door wide open, and after the third layer, I lower the auxiliary fan to 40% and the main cooling fan to 30%.
In the winter, when it’s 20 degrees Celsius, I remove the top glass, leave the glass door closed, and after the first layer, I lower the auxiliary fan to 40% and the main cooling fan to 30%.
With the h2d, having all the ventilation systems, how do I set it up?
I’d like to know your settings with the door, the top glass, and the various fans, both in hot environments like summer and in cold ones like winter.
