H2D Infill other fillament
Hello,
Is there a setting that allows me to choose which filament is used specifically for the infill?
I want to print a pulley using a more expensive material for the outer walls and top/bottom layers (Filament 1), and fill the inside with a cheaper filament (Filament 2). So essentially, all walls and top/bottom should use Filament 1, and only the infill should use Filament 2.
Is this possible with current slicer settings?
There isn’t a specific setting to print infill in a different filament but you could use a modifier to print the interior with a different filament.
Is this an external program? or do you have an example?
