H2D issues - System abnormal, can't upload logs and won't read nozzle info
Just posting to see if anyones had similar, I’ve started the ticket process with BL, but given they don’t actually read what you’ve put and it takes 3-5 days per reply, hoping to get some insight here!
Started off with “System state is abnormal; please restore to factory settings.”
This initially went away with a reboot, but then kept coming back. So I did what was asked, restored to factory settings and had a couple of days error free.
Sadly the error started coming back again, restarts again temporally fixed it, but it would return seemingly randomly. Ticket logged to BL, also found out at this stage, that it wouldn’t upload logs to the ticket as that kept failing… BL replied 3 days later, asking me to restore to factory settings (I was very clear I’d done that) and asking me for logs, so I’ll have to figure out how to do that via USB and upload on web (which is fair enough).
Yesterday I found out that the read nozzle function also doesn’t work, when you click to read, you just get the spinner and nothing else happens.
I tried downgrading firmware, but it gave me the System abnormal, restore to factory settings error, literally just after I did that process for a second time.
Anyone had similar? Other than the dodgy cooling fan, it’s been working fine for 570+ hours.
Upgrading the firmware again and hoping to get the original error back so I can manually get some logs to get over to BL.
