H2D Maintenance
Hi. Does the assistant inform you with every necessary maintenance?
Or are there ones that it doesn’t inform?
Also how do you understand when your PTFE tube has worn out?
The system provides reminders to clean the laser and to lubricate the lead screws, but I am not certain whether it issues alerts for other maintenance tasks.
PTFE typically shows signs of wear once filament feeding issues begin, but it is advisable to replace it before reaching that point. Using reinforced filament will cause PTFE to wear out faster compared to standard materials such as PLA.
It only tells you about the z screws, not the other two, but you should regularly clean and re lube the XY regularly, and I mean more than you think you should. The cleaner and well lubed the XY system is the better.
Thank you.
The 2nd or 3rd day after I received the H2D it informed me to lubricate the z screws with grease specifically.
On this page it tells you to lubricate it every 3 months:
https://wiki.bambulab.com/en/h2/maintenance/period-maintenance
The maintenance information only came with one of the last firmware upgrades, before that there were no messages at all on the H2D
