I would very much like to see a Synchronize checkbox on the speed tab of both the global and object menus. The sync button does not work well, and also it is very annoying to click for every. single. modifier. It would keep all speeds identical at all times after checked.
I second this 100%.
I was going to open this issue. Glad it is raised already.
That is an elegant solution.
For those that don’t understand the problem, it is this:
In process Settings, Speed tab, the Synchronize Nozzle Changes (from left to right, or right to left) button should also have a synchronize current, or COPY these settings to the other side, otherwise if you Save the preset there’s no way to copy settings over we have to enter them all manually. The flag logic is “Has this nozzle’s speed setting for a given parameter changed since the last time this Process preset was saved?”… that’s just too limited… many times I’ve saved a preset, then gone back to check my ducks… and low and behold… I was editing the left nozzle… guess what… 99% of my printing has been done with the right nozzle from the AMS2… A way to change the default nozzle would also be REALLY GREAT!
Thanks everyone!
