H2D Poor Print Quality
@WisestMoose, I can’t remember… did you try the Beta firmware update to see if the problem was simply a bad or corrupted line of code?
I had tried a fresh install. Just tried a print with the newest release. Same under extrusion. Support thinks it’s a faulty filament but I am getting the same results across brands and matte vs basic. So hoop hopping currently.
Just to eliminate an obvious possible disconnect: I assume you know you need to change your filament profile to incorporate the calibration results for flow rate? Just running the calibration by itself won’t change the filament profile for you.
If the answer is yes, you’re doing that, then what happens if you set the flow rate in the filament profile absurdly high? Are you still getting underextrusion even then?
Also, I don’t think you will notice a change in any of the pre-sliced models, like the benchy, because all filament profile assumptions are already baked into those models.You would only notice the improvements on models you slice yourself. If you’re using profile settings from makerworld for a model you downloaded, by default those would override whatever settings you have, and may not be appropriate.
I do change it to the calibrated option when I slice it.
I have done a forced flow ratio of up to 1.08 with the under extrusion but was worried to try higher in case it did something weird to the printer. I am reasonably new to printing.
I get this in pre sliced ones and ones I have sliced myself. It happens with both simple and complex shapes.
If it’s still largely underextruded at 1.08, there’s no harm in inching it up from there. Just don’t make too big a step up per iteration, or the nozzle might drag itself over the top of an overextruded layer. I’ve had filaments where, IIRC, the perfect flow rate was something like 1.15, for instance.
Also, worth of note: it may turn out that the perfect extrusion rate for the first layer is different than for subsequent layers. The slicer allows you to set a different flow rate for the top and bottom layers.
@WisestMoose I can’t remember if this was suggested previously… Have you tried starting a print (Benchy) and then switching to the Silent mode to slow it down? I’m thinking this would help to clarify what bucket the problem falls into because the slicing would be a set known value and the only change relies on the printer’s Silent mode. If the print cleans up perfectly, I would think the issue is mechanical and in the extrusion system. If the issue remained, I would think the issue is outside of the mechanical features because the limits aren’t being stretched in any way.
WHATSAPP +18162871409 TELEGRAM @str8dropzlife. We sell quality Captagon tablets. We have been in the market for over 15 years now and stand as the leading supplier of the best Captagon tablets. We ship world wide and offer 100% discreet and sophisticated discreet packaging. We have discreet packaging that passes through the though controls at the boarders. We have a 100% delivery record to all our packages. We sell at very good prices and offer the best discount prices to our buyers and our bulk buyers have the privilege to pay part upfront and complete the balance 2 weeks after delivery. That is just for bulk buyers who order 10000 tablets and above.
If you are looking for the best quality Captagon tablets, then you have found the solution because we will not only offer you quality products at moderate prices, we will also offer the best delivery you can imagine with option of an overnight delivery.
As for our prices, below is our price list
Captagon 50mg
100 pills…$300
200 pills…$500
500 pills…$1000
1000 pills…$1500
2000 pills…$2200
5000 pills…$4500
10000 pills…$8000
20000 pills…$15000
50000 pills…$35000
100000 pills…$65000
captagon pills
captagon pills wikipedia
captagon pills what are they
captagon pills side effects
captagon pills price
captagon pills effects
captagon pills definition
captagon pills price in india
captagon pills price in pakistan
captagon pills uk
captagon pills uses
captagon pills what is it
captagon pills australia
captagon pills in arabic
what is captagon tablets
captagon drug effects
captagon pills benefits
what is captagon pills
captagon pills canada
captagon pills composition
captagon pills cost
what is captagon drug
how does captagon work
captagon pills uses in urdu
captagon pills uses and side effects
captagon pills dose
captagon drug side effects
what do captagon pills do
what is captagon
captagon effects
side effects of captagon pills
what is captagon made of
effects of captagon
captagon pills for
captagon uses
what are captagon pills for
is captagon legal
captagon (fenethylline)
captagon pills meaning
captagon pills in hindi
captagon pills in hindi uses
hamas captagon pills
captagon pills uses in hindi
captagon pills in pakistan
captagon pills in usa
captagon pills in news
captagon pills price in india online
captagon pills legal in india
captagon pills meaning in tamil
captagon pills price in india online amazon
captain pill
captagon pills lebanon
is captagon addictive
captagon lebanon
what is captagon pills made of
price of captagon pills
captagon pills price in usa
captagon tablets price
fenethylline china
fenethylline dosage
fenethylline deutsch
fenethylline duration
fenethylline dose
fenethylline definition
define fenethylline
drug fenethylline
what does fenethylline do
fenethylline experience
fenethylline hydrochloride effects
effects of fenethylline
side effects of fenethylline
fenethylline fentanyl
fenethylline function
fenethylline frank
fenethylline. talk to frank
fentanyl vs fenethylline
what is fenethylline hydrochloride used for
fenethylline gray zone warfare
fenethylline half life
fenethylline hydrochloride street name
how is fenethylline made
synthetic routes of fenethylline hydrochloride
fenethylline india
fenethylline in pakistan
fenethylline ireland
fenethylline indication
fenethylline ingredients
fenethylline is fentanyl
wat is fenethylline
is fenethylline illegal
fenethylline kin
kin fenethylline
fenethylline legal
fenethylline metabolism
what is captagon pills side effects
what is captagon pills in india
is captagon legal in us
Where can i buy fenethylline in middle east
Buy fenethylline in middle east online
Captagon
Captagon Middle East
Captagon Syria
Captagon uses
Captagon structure
Captagon in Arabic
telegram handle @str8dropzlife
Proton email:str8dropzlife@proton.me
whatsapp : +18162871409
