Hey CarbonForge,
Always great to hear from you, so thanks for taking the time.
Having said that, I am not sure if your response was directed at myself or AlexE1978 ?
Either way, to address what you said a little - respectfully, kind of seems you did not fully follow all the threads, including my own, on the matter. Apologies if I’m talking rubbish, I mean no offence.
As I said, we already know the noise is coming from the motor, even though it’s not super easy to pinpoint as it resonates through the chassis and screws a lot.
Swapping said motor for a new one does not fix it. Swapping screws and nuts does not fix it. Retightening and resitting the belt does not fix it. I personally have no abnormal play in my screws. This does not seem mechanical, nor specifically motor related. I asked bambu for a new MC board, thinking perhaps there driver side is at fault, having ruled out mechanical components including the motor itself. They said no. As far as my limited understanding goes, this is the last component in the z chain that has not yet been swapped to see if there is any difference …
I have been in touch with bambu RnD team about this (well, they were in touch with me), and even they, despite acknowledging the issue and calling the noise abnormal, are not confirming what component is causing this nor providing a replacement for it. Quite the contrary, they specifically said replacing MC board will not help and said to wait for firmware… or replace the printer which they also offered…
So respectfully, I kind of feel like the big leagues, including yourself, have not gotten properly involved in investigating this, likely because your printers are not affected and there is little you can actually do remotely.
The advise we received, if I remember correctly, related to checking backlash and wear on the nuts, then same for the stabilising sliders and not much else…
The noise comes from the motor though, which seems to be collectively ignored by everyone as if it was impossible.Bambu has kind of confirmed it is the new motor noise cancellation that is causing it, having issued Gcode that runs the routine for z axis only, with extra undocumented parameters. Did not help me despite 3 different Gcode versions I received from them. Thy said this helps others.
They also said firmware fix will include a different solution to those Gcode, so even if those don’t work, firmware will.
Long story short - it’s formally confirmed to be an issue. Z motor noise compensation related. Bambu swears no part swaps will fix it, which is hard to believe, as replacing the printer will, so swapping ALL the parts fixes it, surely we don’t need ALL of them to be swapped to fix this, just one … but Bambu is refusing to say which or provide it …
So there we have it. I would love one of the smart guys to lay their hands on an affected printer and share thoughts with us, as I am sure you could tell us more than bambu does…
And naturally, you are 100% correct that prints are fine and the printers are not getting destroyed. So it seems it’s one of „ high annoyance, low impact on functionality” issue which undoubtedly has low priority for Bambu.
It is annoying though, terribly so…and can’t shake the feeling I would rather have a printer from the „not affected pool”… for the piece of mind having a unit that matches the standard tolerances and QA.
