I would like to check if offline update works with H2D (they claim that it doesn’t work right now, but in the menu you can find offline update section, so i want to check it out)
My printer is region locked, so i cant do it myself and i still would like to try update it offline, so can anybody get the update link if possible?
I assume the traffic is https, and so the endpoint is probably encrypted. May be able to get the IP or plaintext site, but not the path. Trust me, I was curious of the same thing.
There’s one Korean guy who forced update through MQTT, he has guide for all printers except H2D, somehow he got the link. I tried to check through different MQTT requests (i thought maybe link could be hardcoded) but still no luck. So im waiting for his reply.
I seems to found a way to do this, but i need someone with global version of H2D with a latest update, it’s just one simple MQTT command, if someone could help me with that, whole chinese owned printer community would be grateful to you
I’ve tried this method and it doesn’t work, apparently Bambu decided to remove firmware history from MQTT which means that you can’t get link anymore, but if you are curious here’s the link of that post.
I’m facing the same issue—I unknowingly bought the China version without realizing it was region-locked. I tried to find a VPN with a China Mainland IP, but had no luck. Most VPN providers only offer servers in Hong Kong, not in Mainland China.
If the software is open source [I haven’t looked, tbh] then yeah - diving through the code would show it.
But so would firing up WireShark in promiscuous mode and watching the traffic - or having a router that allows you to capture/investigate traffic. Honestly there are a LOT of ways to figure it out.
Now there are ways for them to ‘lock it down’ so that even if you had the URL, you couldn’t get the file, but I suspect that’s not the case.
Ehhh. For what it’s worth - I’ve been in the ISP / web hosting / CDN field as a systems administrator for 20 years.
Obfuscation is just that - obfuscation. Ultimately if the files are available to download - it’s possible to do so even if you have to jump through some hoops.
they can make the url only be available for example 5 minutes, what are you going to do about that? sure you can get the package yourself but that means you’re responsible of sharing that firmware pack afterwards
If they are distributing new firmware to their printers, I’m not sure why they would only make it available for 5 minutes.
What would be much more likely is that they require a PSK to download the file. A PSK would be shared over SSL and encrypted - but if the software is open source - it may contain the PSK… but they could always strip it.
Realistically - I don’t think there’s any obfuscation or anything funny going on - just that they aren’t publishing the URL to the package so you have to find it yourself.
Having a short TTL isn’t unusual, sure, but if you are distributing software to your devices you generally don’t want the software to disappear after 5 minutes.
