H2S+AMS2+HT - do I need AMS Hub and extra power supply?
Looking at the H2S Ams 2 pro combo and adding the HT Lite singleroll ams…
But do I need something else for this to work such as
AMS HUB
Some kind of extra power supply?
I used the PTFE Adapter that Bambu sells, worked perfectly. Bambu 4-in-1 PTFE Adapter | Bambu Lab US Store
As far as power, I’m not 100% sure but the HT seemed to run just fine with only the data cable plugged into the AMS2, and the AMS2 plugged into the H2S I’m using. I went ahead and plugged in the power cord too, but still not sure that’s needed, maybe if drying at high temp I guess. I didn’t find anything in the instructions on this particular question.
I have the H2D and with it you can print from multiple AMS/AMS2/AMSHT without the power supply. If I print from one and dry from the other it works but I get the message that it could dry more efficiently if I had the power adapter connected.
You need the power supply only for the Drying mod.
Just the 4 to 1 PTFE adapter, nothing else for printing.
You do need a power adapter for the AMS 2 if you want to get the best drying performance when more than 1 AMS is connected to printer, but its not mandatory.
Finally there is no hub available that is compatible with the H2 series, its a thing of the past.
I recently got an HT AMS, to match to my H2S and AMS 2 Pro. There is a power cord with the HT AMS, and it seems needed. But otherewise it all plugs together and just works as long as everything is plugged in with the cords provided. You will need a PTFE Adapter as mentioned before, so be sure to order than along with the above setup.
