I have a H2S, and an AMS2 Pro (not the combo, each was purchased separately), purchase a couple of months ago direct from Bambu. Both machines are running the latest firmware.
When feeding from the AMS, at the end of every print task, the cutter is supposed to cut the filament so it can be retracted. Up until late last week, this was working fine. Now, when the print task is finished, and the tool head moves to the right side so that probe can push the cutter, the probe that actually pushes the cutter lever is misaligned by about 30 degrees, and when the tool head detects this, the printer throws this error:
Can’t cut filament. Check the cutter.
[07FF-8001]
If I press the Retry button on the display and wait for just the right moment, I can manually push the probe into the correct position, and the filament is successfully cut. FWIW, it’s not being misaligned at random angles - it’s always the same misalignment, and it’s notchy, so it’s something built into the mechanism that holds it at this position.
I don’t know if this is an AMS or printer firmware issue, or if it’s a physical defect on the printer itself.
Has anyone else seen this behavior? I submitted a ticket to Bambu, but honestly, based on other reports of the frequent failures on the part of Bambu support staff, I’m not hopeful that they can/will fix the problem.
