Handy App firmware upgrade/downgrade option gone?
Regarding A1
I’m using the iOS version of Handy App and no longer can find the firmware update/downgrade option. Was it removed? If so, that sucks. I was having an issue updating the FW via wifi and was going to use the app. Could not find the option. Did it via SD card, but now it looks like there may be no way to roll it back if something goes wrong.
On a related note, after I successfully did the update via SD card, it still tells me there is an update after powering up, even though there isn’t one.
On the main page of bambu handy (devices), click on the square with the gear (1st icon on top right), select firmware version
Good grief. I swear I looked there a few times. Thanks.
As for the new firmware nag screen at boot after already updating viva SD card, It still kept failing via wifi. I had to connect to a different hotspot and it finally downloaded and installed (again). Not sure why it was giving me a fit on the original wifi because everything else worked fine (i.e. sending pints via the app or BS). Also not sure why it was nagging after updating via SD card.
