Has anyone DIYed a G10 build plate for their H2?
I have an H2C and an H2S. Love them. Yay. I print almost exclusively ABS. For that I use the Engineering plate from Bambu. Unfortunately I have found the plates don’t last the longest and begin to fail around the 1000hr mark. I’ve ordered the Cryo Pro Glacier to try out.
I would also like to try out G10 but the cost of the plates (Darkmoon) is more than I want to spend for a trial. I noticed the X1 folks did some DIY plates with moderate success. Has anyone done this on the H2?
I am thinking of just adhering a 0.5mm sheet of G10 to one of my scrapped plates and sending it. Are there any issues doing this with the H2? Must the build plate be the same level is the nozzle clean area or nozzle offset area?
If you need to test this empirically stick thin cardboard to your existing plate to raise the surface, and see if it still levels. Cardboard should in theory not damage the nozzle if it hits it from the side.
I think it should be ok with 0.5mm, but i have never tried it
FWIW, the thickest H2C plate I own is the DM CFX/Satin combo (Duo) which is 1 mm thick (a thin CF sheet stuck onto a thin metal sheet, quite stiff). The thinnest (Glacier) is 0.6 mm. I don’t see why an even thicker plate wouldn’t work (within reason), but haven’t tried.
-Max
PS. The steel half of the Duo plate measures ~0.7mm which is almost identical to the Engineering plate thickness.
Nozzle would poke through cardboard when printer tries to home.
You could make the plate 3mm thick and the leveling would still work. It uses the pressure sensor attached to the nozzle to figure out once it’s touching the plate. Cardboard may not be the best material as it’s soft potentially. Depending on the cardboard the leveling could get inconsistent readings and fail
have glued a 1.5mm garolite sheet to a cheap aliexpress plate with double sided tape.
no issues with bed leveling. the bed leveling sensor detects the nozzle touching the bed.
i once accidentally “homed” on a cardboard box which was covering a filament spool (for drying)
