Height of Connector
I have a half a circular pot. I want to add connectors. How do I determine the 2 are of the same height? Meaning, when I cut the pot down the middle, I need to place a connector on the 2 ends of the half pot until I then cut it in half for quarter pots.
I know when u cut something once, the connectors automatically line up. But not when i cut a circle in half. The connectors will not be facing each other, but will be on opposite sides.
I was able to measure 1 to the bottom, but now can’t. The measure tool often just gives me the angle (because the 2 faces have different directions), not the distance between the connector and the pot bottom. Actually getting the X-axis positioning of the connectors would be good too.
Thanks
PS. I know in the end I need just 2 connectors, on each end of the eventual quarter pot. So I need just 1 connector position to match up to the other end of the quarter pot.
con disd.mf.3mf (274.1 KB)
