Like the title states, the Flexi Rex Xmas dinos I am trying to print for my sons school aren’t happy. I printed one ok and when I multiplied it, it went to ■■■■. I changed a few options to refine everything.
I since turned down the flow ratio from 0.98 to 0.94 and checked avoid crossing wall. Now I am running another test but at 27 hours per print, I have time to discuss troubleshooting. Let me know your thoughts please!
What type of filament? Did you dry it (not sticking well)?
You might need a higher bed temp or the filament might just need to be dry. That close-up, the top layer looks suspect like maybe the filament is wet and gives a bad surface that can get caught and pulled off the plate by the next layer, not as much of an issue with a single rex.
You will get way less per plate but per object mode might work around the issue altogether.
