Help file stl
i need some help to get this fixed to simple.
now its al little parts.
can someone fix this form me,
i deleted the original by accident.
the side is normal smooth. and way less polygon or how you call it?
thanks for the help
file1
i just remade the design, but im still wondering if its possible
i also saw you can rename it to zip, and then the only file i see usefull
is with .model. but can we do something with that.
thank you
Your overhangs are unsupported and cantilevered too far. Lots of ways to fix: wider line width, shorter layer height, use supports, etc.
support is been used, see image?
the 1 images that was the support?
all overhang was supported?
also its bambu filament , and i used the correct standard settings, so why i not to change that?
not is need
thank you
greetings
