Help h2c broke after firmware glitch
To follow up on that comment:
This really should only be done after talking with support and getting clear instructions from them - not just because someone saw it on Reddit or anywhere else.
That’s not actually the solution to the problem, but rather a last-ditch attempt to get the printer working again. In many cases, the circuit board still needs to be replaced.
The pins essentially reset the board - so they’re service pins. A switch was planned, but since it’s used so rarely, the switch apparently wasn’t built in. These are really only very specific situations; not a solution to the problem, and strictly after consulting with support.
By the way: That’s not how you do it! - Found on Reddit.
And why should you contact support before doing that? Because you’ll probably need to work through this guide first to make sure that no other essential components are defective:
The thing is, what often isn’t posted on Reddit is that there’s a whole guide that comes before it.
Ya i read the not powering on wiki and all the lights were all good and green. Ans when that happened the printer had just done a print job and was all working. The only reason I power cycle it as because I changed a filament in thr ams to start a print and it wouldn’t read it. When I power cycle it everything lit up except the screen. And the problems I saw people had were eerily the same exactly as I was having with videos confirming the same symptoms. So I didnt just try a random solution. And all the calibrations work except for the nozzle offset one once it hits time for the left nozzle
It’s the pandas in the factory. They are being fed the wrong kind of bamboo shoots,
I can already picture someone trying to bridge the live circuit with diagonal cutters, just like in the image. Oh right, a pirate hack to avoid taking half the printer apart for the diagnosis :joy: What could possibly go wrong
Failed calibrations, I find are often due to the order in which they are done.
  1. Calibrate Live View Camera.
  2. Heat bed levelling
  3. Nozzle clumping detection
  4. Nozzle offset calibration (I always do this last)
If you have a vision Encoder, calibrate that after bed levelling.
Not saying this will fix your issues but it has fixed numerous Nozzle offset calibration issues, especially for calibrations with collisions that have been saved in the bed levelling previously.
