Help Identify Part
My initial thought was that it was kapton tape to prevent heat transfer from nozzle to arm to magnet, causing it to overheat and lose magnetism.
Its definitely not magnetic as previously suggested… I’m playing with mine (which fell off yesterday). It has a purely adhesive attachment. Its definitely a simple tinted transparent piece of plastic.
I’m not sure how they expected this to stay on for any significant amount of time. Seems as though it was bound to dislodge and fall off at some point. The adhesive wasn’t terribly good.
Personally, if they were worried about friction, if might have made more sense to increase the deepness of the hole by 0.25 - 0.50mm. However that small change would likely cost a lot, so this may be a late cycle band aid.
I’ll probably leave mine sitting in the accessory box and not worry about it.
I got the reply regarding putting it back (which adhesive) from Bambulab:
We do not recommend using any adhesive, as it may affect the magnet’s ability to hold.
You can try gently placing the part back on. If it doesn’t hold, that’s okay.
Mine came off today.
Cover of the magnet, not magnetic cover
mine fell of too… i cant really imagine this thing will stay on long… its not sticking good… pretty sure this thing will mess up a few ppls print… i put it back on but if it falls of again i wont put it back on…
i only had one down there…
Mine fell off today. Their response does leave you wondering if they used magic, or hopes and prayers to attach it originally.
