Hi all
I have some spikey stuff I’m trying to print and it fails constantly, often after 12+ hours of printing. Printer is an X1-C that other than this runs flawlessly.
The problem comes from it being multicoloured. I’m saying that as if I print them in just one colour, they work fine.
Essentially, at some stage one, or more, come loose and take the others out with them sometime later. Even when I’ve caught one in time, and skipped it, another is bound to go later. I’m getting less than 10% working.
I think somehow the print head is knocking them off, rather than them just gently coming loose. However, that’s just the feeling I get and it may be wrong.
Also, I often find a layer shift at some point, mayve 0.5 mm max. My feeling on this, though it is a guess, is that the plate has shifted as the errant spike is shoved around. I think this as it’s not always the same height, and if it’s ther,e it will be on every single object.
Other things to note:
I don’t have any printing problems other than this one model. Even then, it’s only the multicoloured version.
I print with a brim. The brim stays put when the object(s) dislodge. I’ve even made the brim larger but that doesn’t matter as the brim stays on the plate and the onbject detatches.
Ones that haven’t dislodged seem firmly fixed to the plate.
Slow first layer and all the usual stuff to improve bed adhesion, such as a gluestick.
After so many failures, I even changed the model, as in the photos, so the base isn’t the tube but has a solid bottom layer, which I would then have to remove with a blade. This didn’t help at all.
I used to have a little more success with this, but still with many failures. I upped the walls (from 2 to 4 I think) and increased infill. That didn’t help and may have made things worse. I’m not sure about that though but it might help someone suggest a solution.
On the rare occasion one has printed properly, it’s come out really well.
Photos attached to show you the basic object. I print them with the tube upright and the (newly added) solid round base on the plate.
Has anyone got any suggestions as to how I can print these successfully?
