Hello all! Working on a design and I’m seeing some strange horizontal lines on the surface after printing it. This does not show up in the slicing preview. It is a pretty simple sketch I created in Fusion 360. Just a 6mm thick extruded surface with 4 circular holes going down 2mm. I printed using 0.16 high quality setting (15% gyroid infill). I believe all other settings are largely default. Any thoughts as to how to remove them or hide them? Thanks in advance!
I am having the same issue on my X1C only 10 times worse. It’s like the nozzle doesn’t get set back at the right depth after it travels over the hole. The sheen of the printed filament is different as well. Like the hole is actually in motion and leaving a trail if that makes any sense lol. Maybe someone has some insight
