Help with PETG and diagonal/slashed gaps/holes/overhangs/bridges
Hi All,
This is my first time really printing with PETG. I don’t think I have any bed adhesion, warping or stringing issues, others parts in this model printed fine.
But I seem to have an issue with diagonal/slashed gaps/holes/overhangs. Not sure if this is an issue with my settings or with model. Circular and oval gaps/holes/overhangs that are also in this model print fine.
I’ve looked at several tutorials and videos, I’m printing some calibration stuff right now to try and work it out, but just wondering if anyone has any ideas or suggestions.
Printer: Bambu Lab H2S:
Material: Bambu Lab PETG Basic (Original version from a couple of years ago), fully dried.
Using the default profiles for both, with the following modifications/additions
Nozzle Temperature (Initial Layer): 255
Nozzle Temperature: 265
Bed Temperature: 80
Max Volumetric Speed: 10
Initial Layer Speed: 20
Initial Layer Infill Speed: 80
Outer Wall Speed: 125
Inner Wall Speed: 200
Sparse Infill Speed: 200
Internal Solid Infill Speed: 200
Top Surface Speed: 150
Overhang Speed (25%, 50%): 20
Overhang Speed (50%, 75%): 20
Overhang Speed (75%, 100%): 10
Part cooling fan
Initial layer fan: For the first '3 layers', Fan speed '0%'
Linear ramp up to: '0 layers'
Min fan speed threshold: Fan speed '20%', Layer time '30s'
Min fan speed threshold: Fan speed '60%', Layer time '12s'
Keep fan always on: 'Checked'
Slow printing down for better layer cooling: 'Checked'
Don't slow down outer walls 'UnChecked'
Min print speed: '10 mm/s'
Force cooling for overhands and bridges: 'Checked'
Cooling overhang threshold '10%'
Overhang threshold for participating cooling: 100%
Fan speed for overhangs: 50%
Pre start fan time: '2 s'
Auxiliary part cooling fan
Linear ramp up : At layer '0 layers', rampt up to: '0%'
Since you are new to using PETG, lets start with the basics.
  1. Dry you filament. Fresh out of the package is no guarantee it is dry, especially PETG. PETG is more sensitive to moisture than PLA.
  2. Go back to the default settings and perform a filament calibration for pressure advance and flow ratio.
Another interesting question: which PETG do you use?
I found that most brands of PETG behave roughly the same. With PETG, there are much bigger differences between brands, especially at higher volumetric speeds.
Thanks, yeah I did dry the filament for 8 hours at 65C in a EIBOS Polyphemus.
Let me try your second suggestion. I had some initial bed adhesion issues with the default profile, before printing my first full PETG model, but let me reset it and calibrate.
I’m using:
Bambu Lab PETG Basic, the original Bambu Lab PETG Basic from a couple of years ago, before they discontinued it, then reintroduced it.
Ahh, that fully explains the issue. The original PETG basic was really terrible, with issues similar to yours and worse.
I got it to print somewhat ok at drastically reduced speeds, all speeds at 80 mm/s made it ok. And I think the old one needs slightly higher temperatures than BambuLab’s newer PETGs, maybe +10°C. But I would try low speeds first.
Other PETGs still look better even printed at full speed.
For the original PETG experience, I share this lesson learned:
I also use the “Generic PETG” pre-sets rather than the “Bambu PETG” pre-sets and tend to enable “wipe on retract” (both checkmarks).
I looked up the Polyphemus and specifying a time and temperature may not be adequate for a good dry. The more reliable indication of dry filament in most filament dryers is the chamber humidity that you hit at the end of the dry.
The Polyphemus has desiccant holders - do you have fresh/dry desiccant in them? And do you know what the humidity was at the end of the dry?
Can’t say for sure but it could be the filament wasn’t actually dry. Or maybe it was. I’m not experienced with the original PETG Basic but PETG HF and the new PETG Basic both print much better when nice and dry.
