HI My A1 is not feeding
Hi, My A1 is not feeding. It was playing up, but I left it. I had ordered a Harden extruder from Panda. But I fitted the new extruder, and it was still the same, and I stripped it down to double-check. The gears turn with my finger, so they are not stuck. I rerun calibration. It does poop little bit out, but that’s it, and each time I put a new nozzle in.
It says failed to extrude AMS slot 1. The extruder may be clogged or the filament too thin. I use Sunlu. I have taken filament from my other AMS and gone from PLA Plus 2.0 to PETG. I have checked; nothing is blocked by putting some filament to run through. Any ideas help, please. I have used 3 different spool slots that will not work. It will load and load using AMS. But I have to pull the filament myself. Now I have used an external spool, and it is printing ok. So it’s got to be Ams lite that’s faulty.
