It appears that the H2D may not perform as professionally as it has been marketed. While it offers versatile tools such as laser, pen, and cutting modules, pushing the machine within its stated specifications reveals unexpected and hidden weaknesses.
I have been running the printer continuously for several days under high-temperature conditions—65 °C chamber, 120 °C build plate, and nozzle temperatures between 300–350 °C. After about two days of near-constant operation, the HMS system began to report unusual issues. One of the most notable was abnormal bed leveling values, which caused the printer to abort a print mid-job—even though no bed leveling occurs during active printing. This resulted in a lost print without any external cause. The plate was stable, the nozzle was clean, and no filament debris was present under the build plate.
Other anomalies included filament loading errors, even while printing continued normally. While this did not stop the job, it was still a concerning inconsistency. These are just a few examples from a wider set of errors observed when operating at the higher end of the temperature specifications for extended periods.
For troubleshooting, I disassembled the extruder, inspected and replaced every PTFE tube from the AMS to the printhead, and cleaned the build plate meticulously. No issues were found, confirming with certainty that the cause lies elsewhere in the system.
Repeating the procedure after cooling the system back to room temperature produced the same errors again after approximately 48 hours of continuous high-temperature printing. This time, I used only small test models to avoid wasting valuable material.
Something to keep in mind when pushing the machine at the upper end of its specifications: the most critical problems are those that immediately stop an active print. These not only waste valuable material but also result in direct financial loss, making the issue more than just an irritation.
The concerning aspect is that there seems to be little interest from Bambu Lab in identifying the root cause. It is difficult to believe the system has been thoroughly stress-tested under continuous high-temperature operation, as these errors appear consistently when running at the upper end of the specifications. The issue may be linked to prolonged high chamber and bed temperatures without cooldown intervals. Investigating this is time-consuming, and frankly, it is the type of validation testing that should have been carried out by the manufacturer in the first place.
