Ok, but pay attention that our Engineering side is damaged, not HT one. And not damaged while removing the printed detail, but damaged from the hot plate, because the Engineering plate seems made of material which melts.
Not sure how this translates to A1. If you put any kind of buffers between hotplate and the plate it will be uneven.
Not if the buffer covers the whole hot plate⌠as it does in the X/P series.
suitable for x1 and p1
could A1 listing be a mistake ? with store ?
Indeed, you are right. I was thinking stupid things while looking at the red rectangles ![]()
Apologies as I just reused a picture from the wiki as I didnât have one.
Can you share link? I canât find it as a spare part in Bambuâs store.
princore.de/products/magnetplatte
a have chosen 280mm so i can cut it by myselfâŚ
I got mine with the printer. It should be suitable, not just typo in their page.
Yes but they ship with textured pei as default .
And perhaps that ad a little down the page could do with updating to suit as its the reason i asked
Well, the conclusion is that in the A1 model, the high-temperature plate can only be used on the engineering side. If we use the high-temperature side, the engineering face will melt. And all this happens because the A1 doesnât come with an intermediary sheet between the bed and the printing plate that some of you are buying separately. It looks like Iâm going to submit a ticket to Bambulab for a product I havenât received yet. ![]()
Small additionâŚ
What i tried:
-I put the High Temp Plate on top of the Textured PEI Plate
-run a Bed Calibration over the Printer Touchpad
- printed the science Test while have selected Textured PEI Plate" during slicing.
- print:
an got an medium quality first LayerâŚ
Then i just removed the Hot Plate and hit âprint againâ, so there was not even the small bed leveling it does before print, yust the 2 Contacts with the Nozzle in the middle. And got the 2nd medium quality first layer.
my conclusion: Z Offset is meassured (and set) with only the one contact between nozzle and bed just before the 2 Filament lines are drawnâŚ
so, it should work, to put the extra Magnet Tape Layer under the Build Plate.
But the nozzle whiper has to be lifted too, with 2 Build Plates, the Nozzle does not really reach the whiper anymoreâŚ
We will seâŚ
