Hi all,
i am using a P2S (formerly a P1S) for printing of dental study & implat models if resin is not neccessary (& fdm is so much cleaner and less hassle!)
Regarding regular dental models, the P2S is equal to my resin printer (Phrozen Sonic 4K XL), BUT: when printing dental models for implants, the P2S is noticeable worse than my previous P1S and worse than the resin printer.
What’s the problem:
dental implant models have small holes (3-5mm diameter) and inside there is a triangular structure. A metal calibrated “lab implant” is inserted into these holes and the triangular structure prevents rotation of the “lab implant”. (see here: lab implant).
Something is wrong with the hole and the triagular structure inside. I have to apply great pressure and force to insert the metal lab implant into the model. I will most certainly squeeze the material. When ordering resin printed models at a printing service or if i print it with my resin printer, the lab implant will glide in smoothly.
The P1S was able to print the model with enough precision - the lab implant gilded in smoothly. The P2S seems to be different.
Materials used:
0,4 nozzle hardened
PLA Matte/PLA Basic/PETG HF (all Bambu)
PEI Plate/engeneering Plate with glue (did not make a difference)
Bambu Studio, latest Version & latest Firmware, AMS2 Pro
Setting: Auto-Hole compensation on/off did not have a noticeable effectI tried to do a calibration with califlower which did not have any effect even if a bit of skew was fixed.
Do you have any idea on this? Thank you very much
The .stl looks like this:
When sliced, it looks like this:
