Homing off center, crashing during filament load
My x1c seems lost. When homing it lands off center back and to the left. If I attempt to load filament it crashes into the back and isn’t properly aligned over the poop chute.
This started happening after I did a successful print without issue. I just removed object from build plate, and resent the next print (which was the same model just at a different print orientation so all exact same settings from previous print profile wise.
I’ve power cycled many times. I tried times with it manually moving it all the way to the front corners before powering back on and each time homing lands off center.
I am running the x1plus firmware, but have been basically since it launched with Bambus blessing and haven’t had any issues since.
Thoughts on how to proceed?
Is your nozzle bent?
Char limit
I figured it out. User error.
A while back i had printed dust caps for the front 2 z screws. the front right one was dislodged and sticking up, so when homing it hit that before getting all the way back. Homes fine now
