Hi everyone,
I’ve been printing a lampshade in Spiral Vase Mode. I’ve tried a lot of different approaches, but I keep running into the same issue: horizontal lines on the surface.
What I’ve tried so far:
- Different nozzles:
- 0.4 mm nozzle with 0.8 line width → the lines actually get worse
- 0.8 mm nozzle, fully calibrated → still visible lines and same as 0.4 nozzle and 0.8 with
- 0.4 mm nozzle with 0.4 width and 0.24 layer height → this gave me the best results so far.
- Tweaking settings: more/less cooling, higher/lower temperature, faster/slower print speed.
- Making the model extremely high poly in Blender (up to 5 million faces) in the hope of getting smoother results.
- I printed with pla and petg but same results.
The outcome:
The lampshade is smooth to the touch and structurally fine, but the horizontal lines and banding remain visible. It’s hard to capture clearly in photos, but in real life you can definitely see them, especially when the lamp is lit from the inside.
My question
- Is this simply normal with FDM printing, especially with large smooth surfaces?
- Or are there slicer tricks/settings that could help reduce this effect further?
Any advice is much appreciated!
Thnks and greets
Chris
