Hi All, I’m designing and printing stands for Star Wars Lego sets. Some of the sets can be heavy and I’m concerned about how Bambu Studio is handling the infill. Is there a way to set the infill to continue up through the base to the vertical part of the stand. Currently when I slice the stand Studio is setting the vertical support on top of the base.
It might be stronger if you use a modifier block, place it where the legs go into the base so it encompasses both and make the block 100% infill or many walls so it’s solid.
Thanks for the suggestion. I ran a print and it actually broke off a bit higher than I expected. I’ll try your suggestion and extend it up about halfway.
That worked. I also ended up switching to cubic infill for the vertical sections as well. The stands kept snapping off about half-way up. Switched the infill to cubic for the verticals and that seemed to resolve the issue.
