Hot End scratching Plate
Has anyone seen where the hot end is scratching the back of the build plate and even middle when calibrating. Is this a bug that needs to be fixed? Just checking if anyone has seen it and got it resolved. I have the A1
The back tab of the build plate - Very normal, part of startup sequence, it digs and pushes hard. It’ll be bare steel in no time. No worries
Middle - Not normal, got pics or elaboration? I’d say as a precaution, check the screws on the back of your nozzle holster, a common loosening that commonly interferes with the tap-to-z homing.
Pics at step 2+3 - A1 Series First Layer Print Issues - First Layer Too Low, Hotend Moving | Bambu Lab Wiki
Welcome @byron36065! As Bullocks said, the scraping against the back of the build plate is completely normal. When I was new to my machine, I noticed this as well. Bambu support confirmed that this is completely normal and healthy. Later, they even added a section addressing this on their sales pages for print beds.
Regarding the other scraping issue, I have experienced a similar thing on my X1C. What I did was:
  1. Turn off then unplug machine
  2. Wash build plate with dish soap and sponge (both soft and hard sides only do this for textured PEI )
  3. Rub ISO alcohol onto the plate, let it sit for a minute, then rinse it off (this is done in conjunction with the washing)
  4. Put the bed back on the printer and turn the printer on
  5. Run both a device check and complete calibration
  6. Try printing again.
If the issue persists, contact us again! Good luck to you!
Thank you I did all those things and it seems to be working fine again. Much appreciated thank you. For your time
Thank you did all the info I got from your all and it seems to be working again. Thank you
Awesome! I am glad you are up and printing again!
