Hi,
I am using the cool plate supertack plate for all my prints. It’s a great plate, but the only problem I have with it is that I always have to change the “Initial Layer Flow Ratio” to 0.8 in order to get a good first layer every time on it. The first layer always is bad if I don’t do this, regardless if I use Bambu filament or 3rf party one (Elegoo in my case).
It’s a bit annoying to keep changing it on my pc in bambu studio, but I am getting by. The problem here is that I basically cannot use the bambu handy app to start prints anymore, because the first layer will always be bad (everyone is using the normal “Initial Layer Flow Ratio” setting, which is 1). The only things that I can customize in the handy app are which parts I can print, the color and the filament profiles.
Since we can custom filament profiles that are indeed saved in the app as well, I tried looking through the filament profiles to see of that option is somewhere. But it seems like it’s not.
I am now tempted to just buy a biqu print plate and use the smooth plate/high temp preset since from what I’ve seen online it doesn’t have this problem. Which would be a shame since it does cost quite a bit of money to replace something that actually works great.
Is there any workaround for this problem?
Thanks in advance!
