How can I make top layer fonts higher?
I need help in increase these fonts 1-2 layers up.
I only have the STL - I tried to cut off the numbers, but can’t fit the parts back together.
This made me think that there must be a better way?
Screenshot 2023-08-18 104922
Any ideas? Thank you
If you have the STL, and you have a CAD program that can open the STL, open the STL in that program and select just the top faces of the numbers and drag them up in the Z axis until they’re as high as you want them to be.
You just need to be sure the STL has merged all co-incident vertices so the model is “monolithic”, or dragging the faces will separate them from the rest of the geometry.
Thank you for the reply, BUT I do not have any CAD programs or know how to use. That is why I was trying to figure out a way in Bambu or Prusaslicers.
I assume based on the fact that they are a different colour that they are already separate objects in BS. If so - can’t you just select the text objects and rescale them (non uniform) - to make the Z scale 200%
Download blender 3d for free and use edit mode, then just move some surfaces higher.
I am having this issue when trying to print fonts. The model shows up great in preview, but then after slicing, the letters have gaps. Can anyone help me here ?
