I’d maybe put it like this:
I’m using PVA through my AMS as well, but I keep it absolutely bone-dry. PVA is a bit strange: when it has absorbed a lot of moisture it goes soft and rubbery, gets very stringy, and the supports can turn into a sticky, saggy mess. On the other hand, if you “cook” it too hot or for way too long, the material can start to degrade and then it becomes brittle and will snap easily. So PVA can feel either floppy/slimy or dry and fragile, depending on how it’s been stored and dried.
In general, when filament suddenly snaps on the spool it’s often because it has taken up moisture and weakened, not because it’s truly “too dry”. You can absolutely destroy something like ASA by drying it at high temperature for 48 hours, but that’s more about overheating and damaging the polymer than about normal drying.
Tree supports are usually a bad match with PVA and tend to make the print look messy. I’d try regular supports with tighter settings, and instead of breaking them off, let the PVA soak until it dissolves.
The D20 in a cage I mentioned is printed through the AMS on my X1 Carbon, fully covered in PVA, and it came out really clean. I did get a bit of black bleeding into the red for some reason, but the PVA itself worked exactly as it should.
As I told someone before, it’s also fun to print bait cages for fishing in PVA. Baiting almost becomes a sport of its own: first at the printer, then later at the water when you’re actually fishing.
Speaking of drying: I ran my PVA through another drying cycle in the AMS HT. I always do that before starting a new print if the filament has been idle for more than a day. I also print full models in PVA sometimes, but I use a PVA that costs me about €20 per kilo for that. Bambu Lab’s PVA is a bit too expensive to “waste” on full models in my opinion.
If you share your model and settings, I can compare them with mine. I’m running slightly different PVA settings on my H2D and I’ve never used Bambu Lab’s built-in PVA profiles, simply because they didn’t exist when I first got my H2D.
