I’m another total newbie who knows nothing about 3D printing. I have just purchased and assembled the Bambu Lab A1 and am trying to learn how I can use appropriate files downloaded from the Internet to print the model. I have already downloaded some files to my hard drive. I have downloaded and installed Bambu Lab studio on my PC as well as the Bambu Handy app on my phone, and now want to know how I can add these files to the SD card from there, print the model from them?
However, I’ve been unable to find instructional videos or instructions anywhere on how to do that.
Any suggestions please
Bookmark this, it’s invaluable and a great resource.
and welcome to the forum.
Assuming the files you downloaded are whatyouwanttoprint.3mf then here’s a quick and dirty explanation.
Open up Bambu Studio (referred to here as Studio or BS) and log into it. When you open it you will see “Create New Project” in the top right hand corner, it’s a green button. It will take you to a page that has your build plate in the middle and a bunch of stuff that’s going to confuse you for now. Ignore all of them except the build plate.
Across the top now will be a toolbar with only 2 icons active, (showing lit up, if you will). The first one looks like a box with a plus sign.
Click on that and navigate to the file you’ve saved and want to print. You can also drag and drop the file into Studio.
The file will open and it will be placed on the build plate. You didn’t mention an AMS so let’s just stick with one color at the moment. The thing you want to print will appear on the plate in a color. For now, if you have a color loaded into the external filament holder don’t stress the color too much. We can come back if you have an AMS and want to use that later.
It’s near bedtime so I may end up being too short, but I’m trying not to.
In the upper right hand corner are 3 buttons. For now you can ignore “Upload”. Next are “Slice Plate” or “slice all” if you push the little down arrow in that green button. Either will be fine. Press that.
What is happening is the slicer (Bambu Studio) is going to slice the file into a format the printer can understand. Depending on the model loaded it won’t take too long.
To just get printing now click on “Print Plate” and a window will pop up. This is an important window, as it shows the file, the nozzle/printer, filament, time, all sorts of things. The “send” button should be green, if everything went well. Click it and the slicer will send the file directly to the printer, and it should start printing.
To use the sd card, do everything the same up to the “Print Plate” button. Click the little green arrow beside those words and choose “export plate sliced file” and then a window will open up. Navigate to the SD card and save it there, then sneaker it over to your printer, insert, and follow the directions to load a print on the screen.
Hope this helps, know it’s a wall of text. I’m out for the night but there are a ton of folks that will be happy to help you.
Thanks so much for posting this information, invaluable for a rank newbie like me .
I’ve been trying to figure it out for a week.
Every time I did what I thought I should be doing, it opened Maker World and prompted me to add or download files from there.
Very confusing since I didn’t have any files but had downloaded files from there to my hard drive from where I was eventually able to to proceed.
Had I had the information you’ve provided, I’d still have my hair. lol
You’re welcome.
This forum has a wealth of information across all skill levels. I sound like an ad but it’s true. If I hadn’t helped you someone would have.
Don’t hesitate to ask. We were all new once.
I’d suggest you move the files you’ve downloaded to your hard drive, to the SD card.
Simple enough to do with an sd card adaptor plugged into a USB port.
Slice it in Bambu Studio, then hit send, to send it to your printer. Make sure that you have added your printer to your account.
Do you know how to add a file onto the sd chip
insert into PC, slice file in Studio. Where it says “Print Plate” in the top right hand corner, click the arrow for the drop down. Choose send or send all (if multiple plates) and choose the sd card location in the explorer window.
how do I do it without bambu studio cuz my friends computer that I am borrowing can’t run it because it is a chromebook with 90% of it’s memory taken up by the hated system category
A pre-sliced file on an sd card would be the only way to do it. You will need either Orca or Studio regardless and of course can’t do it on a Chromebook (as far as I know).
Wow this was great thank you! How would I make this multi-colored? We have AMS Lite
