Detailed description of the problem
Printer model used
Slicer settings used
Type of filament used
Photos that clearly show the problem
.3mf file (if the file can be shared)
Any potentially useful information that is related to the problem
I have a printer that has not worked for at least 30 days and I can’t get a timely response to my ticket. Any suggestions. Any have the name and contact number of the president of this company that you can share?
I can’t tell you how to get better customer service but it’s possible some other user can assist if you can describe the issue with as much detail as you have available.
Not worked how? Does the printer wake up and put things on the screen (like error codes)? Does it not even power up? Does it power up and print but the prints are bad? Or is it something else isn’t working? Prints not sticking to build plates, nozzle clogs, etc.
When asking for help it’s important to describe the issue as best as you can. “Doesn’t work” is very general and different people use that to mean different things.
Without a detailed description of what is going on, the best anyone will likely be able to do is tell you to contact support. With a detailed description, if it’s an easy issue somebody might be able to have you back printing fast. But any help you’ll get now is just stabs in the dark.
Early october was holiday for China, [national week] so take those response times with a grain of salt. But yes if you think you have a common problem post it here, or search it within the forum.
