Perfect! You just earned your angel wings. ![]()
The cold plate holds without glue… TOO MUCH. The glue is to help protect the bed, rather than for adhesion. The most important part, is making sure the bed is CLEAN. I also suggest working with a higher bed temp, even on the cold plate. Keep glue layer as thin as possible. I too often wipe my glued bed with IPA and a blue scotts cloth. Again, priority #1, is always CLEAN
PEI plate with 3DLac makes wonders. I apply it once a week, after about ten to twenty prints. I use to print alternatively in different zones of the plate. And now I discovered SYOSS Max HOLD hair spray that does the same as 3DLac does, is 3 times cheaper, and smells good ![]()
Thanks for sharing this. I’m new to the smooth PEI plate and using the liquid glue under PETG as advised by BL. Your post gave me some important pointers that are giving me good results.
