How to add additional presets to Bambu Studio?
Hi, new here. My studio only has .18, .24 and .30 presets. How do I add more presets? I found something that said more should be available than just the three but I can’t figure out where to find them.
The available presets depend on the nozzle size. You do not say what nozzle or printer you are using, but those three presets make me think you have an H2? printer with a 0.6 nozzle installed. You should find other options with a larger or smaller nozzle. Bambu apparently felt that additional 0.6 mm nozzle profiles were unnecessary.
You could modify an existing preset to create a different layer height profile, but you may need to experiment with other settings for optimal results.
AI:
Key Considerations:
  • Maximum Layer Height: Do not exceed 80% of the nozzle diameter (0.8 x 0.6=0.48 mm) to avoid poor adhesion.
  • Minimum Layer Height: 0.15 mm is generally the practical minimum, though thinner is possible, it can lead to high pressure and inconsistent extrusion.
Yeah H2D with .6 carbide nozzles installed. Guess I need to learn about nozzle profiles and whats important and how to test changes made.
