How to add extra nozzle wipe after finishing printing with PETG
I’ve added it to the printer profile as I’m not sure how this interacts with the filament specific end gcode.
This is still work in progress, but you’ll get the idea:
;===== date: 20230428 =====================
M400 ; wait for buffer to clear
G92 E0 ; zero the extruder
G1 E-0.8 F1800 ; retract
G1 Z{max_layer_z + 0.5} F900 ; lower z a little
G1 X65 Y245 F12000 ; move to safe pos
G1 Y265 F3000
G1 X65 Y245 F12000
G1 Y265 F3000
M140 S0 ; turn off bed
M106 S0 ; turn off fan
M106 P2 S0 ; turn off remote part cooling fan
M106 P3 S0 ; turn off chamber cooling fan
G1 X100 F12000 ; wipe
; pull back filament to AMS
M620 S255
G1 X20 Y50 F12000
G1 Y-3
T255
G1 X65 F12000 ; move over poop chute
G1 Y265
M621 S255 ; end tool change
;  extra wipe start
; Wipe the hotend every 10c down to -60c from print temp then turn off
M104 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-10}
G1 X100 F5000 ; wipe right
G1 X70 F15000 ; wipe left
M109 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-10}
M104 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-20}
M109 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-20}
M104 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-30}
M109 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-30}
M104 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-40}
M109 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-40}
M104 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-50}
M109 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-50}
M104 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-60}
M109 S{nozzle_temperature_initial_layer[initial_no_support_extruder]-60}
M104 S0 ; turn off hotend
G4 4000
;  extra wipe end
; disabled, done during extra wipe
;M104 S0 ; turn off hotend
M622.1 S1 ; for prev firware, default turned on
M1002 judge_flag timelapse_record_flag
M622 J1
    M400 ; wait all motion done
    M991 S0 P-1 ;end smooth timelapse at safe pos
    M400 S3 ;wait for last picture to be taken
M623; end of "timelapse_record_flag"
M17 S
M17 Z0.4 ; lower z motor current to reduce impact if there is something in the bottom
{if (max_layer_z + 100.0) < 250}
    G1 Z{max_layer_z + 100.0} F600
    G1 Z{max_layer_z +98.0}
{else}
    G1 Z250 F600
    G1 Z248
{endif}
M400 P100
M17 R ; restore z current
G90
G1 X128 Y250 F3600
M220 S100  ; Reset feedrate magnitude
M201.2 K1.0 ; Reset acc magnitude
M73.2   R1.0 ;Reset left time magnitude
M1002 set_gcode_claim_speed_level : 0
M17 X0.8 Y0.8 Z0.5 ; lower motor current to 45% power
