If i have a p1s with an ams unit offline from the wifi, how do i calibrate filaments and edit k factors inside of bambu studio so that when i print from the sd card, it uses the correct k factor and settings i have selected based on calibration tests?
Thanks
Recent bambu studios removed the pressure advance settings from the filament configuration, so I think you will need to use a 3rd party slicer such as orca. The newer printers will calibrate automatically using the camera but the p1 will not.
So dumb that they did that. I remember it being in there as an option.
I was informed about an hour ago that i could add the gcode to the advanced section of the filament profile in the start gcode.
Thanks for the reply
As long as I remember, there was no PA setting (or k factor) under filament profile. That was why I jumped ship to Orca and that was way before the Bambu Connect
Yeah, they removed it. But the workaround is to add a line of gcode to the start section of the filament profile under advanced
M900 k0.015
I think that is how it is done.
