First, your adhesion is clearly not flawless. 75C on the cool plate is insane. Clean your plate with dish soap and hot water, and use glue if needed and print at the correct temperature.
Also, look at adding brims or mouse ears.
Preheat your build chamber prior to the print.
Finally, make sure your filament is properly dried - it doesn’t matter if it’s fresh out of the bag.
Also, infill doesn’t give you strength, stress is transferred through the walls of parts, you need more walls, not more infill.
I went into a lot of additional detail here.
