How to disable a Post-Purge Move-to-Print before Prime Block?
I print face-down logos.
The issue I’m having is after a filament colour change.
My P2S will purge out the new filament and after completing the purge, will move to the print prior to moving to the prime tower / prime block.
The nozzle will always move to an edge of the printed layers (variable positions) , the bed moves up, and then back down and the nozzle moves off to the prime tower. Whatever small amount of filament was dangling post purge gets deposited on my print.
This leaves blobs of the new colour (small amount) on the edges of the already printed items.
I’m not sure how to eliminate this unnecessary travel.
Anyone else see this?
Thanks…
Heya I have the same problem. Nobody has an answer ?
I managed to find a way!
Under “Quality” tab, disable the “Avoid Crossing Wall” check box.
This absolutely corrected the issue for me.
Good luck!
