Hi there,
I have a support problem (with 2-layer PLA interface) in a PETG-CF part. Using Bambu Studio 2.6.0.51
When the printer reaches the first support transition layer, printed lines between the support walls curl upwards rather than laying flat. This creates a bumpy surface, which negatively impacts the next transition layer and the final PLA interface. Part cooling at this point is low (20%, my 100% cooling setting for bridges is not triggered, what is weird), but I tested to manually forced it to 100% and the result was just a little better.
I suspect that I could fix this by printing the PLA interface directly onto the PETG-CF support walls, but I can’t find a way to disable those two transition layers in the settings—it seems like they’re hardcoded/added by default.
My current settings:
I’ve seen examples where this is possible:
Any help is appreciated
Regards.
