How to ditch the purge tower
Still getting used to my AMS. I was wondering if there was any way to turn off the purge tower. On some of my prints, I don’t mind colors bleeding together. In fact, I think I might like it. I went to preferences and turned it off, or I thought I did, but it printed it anyway. Any help will be appreciated.
Under the Global settings in the Process line, there is Quality, Strength, Speed, Support, Others.
If you select Others one of the headers will say Prime tower. Under there is all the settings for the purge tower.
You may want to keep the prime tower though. Printing the prime tower allows the nozzle to stabilize the pressure that is needed for proper extrusion. Without it, one may run into print quality problems, such as under-extrusion, or surface blobs, in addition to the color bleeding that you don’t care about.
Hmm. Thanks to both of you. If it goes badly, I’ll know how to turn it back on.
