Printing out this logo on my A1 Mini and when I slice it, some of the sharper corners appear to have voids where filament should be going. Before slicing, the SVG I am importing doesn’t have any of the same gaps so I believe it’s either just a setting or a limitation of how well the printers can actually fill in some of these corners.
try with a .2mm nozzle, still may be too sharp even then, but it should get you closer
It is linked to the line width set. So directly dependant on nozzle size.
You may be able to get a bit more by using the Arachne wall generator although that sharp edge may make bed adhesion without nozzle pressure challenging. In practice, you may get decent results if printing white before yellow.
